Votes
0
Product:
iClone 7
Version:
7.92
Status:
Assigned
Issue 8205
No comment possible in Feedback Tracker to older Issues – answer to a new comment from Admin Molly
I have gotten a comment from Admin Molly to this Issue today. „Issue 6557 crash of iClone, when I load a new project, when the script is running
But there I can’t comment more.
https://www.reallusion.com/FeedBackTracker/Issue/crash-of-iClone-when-I-load-a-new-project-when-the-script-is-running
The same at this issue, which could be connected with the first.
Issue 7294 Crash - when I close iClone with the loaded Python script
https://www.reallusion.com/FeedBackTracker/Issue/Crash-when-I-close-iClone-with-the-loaded-Python-script
Feedback Tracker Admin Nov 3, 2021
Hi Tesira,
Can you try it in iClone v7.92?
Molly
Reallusion
So I answer now here.
Hi Molly,
I have tryed my wave script with iClone v7.92. When I load the script, I get now an error in the line 80 from RLPy.py.
The line is: raise AttributeError("'%s' object has no attribute '%s'" % (class_type.__name__, name))
More dos not happen, the script dos not work.
Tesira
OS: Windows 10
  •  4
  •  1078
Submitted byTesira
COMMENTS (4)
Tesira
I have tested some more. The same error message in the line 80 from RLPy.py. I also get with the examples from the wiki here:
https://wiki.reallusion.com/IC_Python_API:RLPy_RIDialog
https://wiki.reallusion.com/IC_Python_API:RLPy_RDialogCallback#_init
More dos not happen, the scripts don't work.
Tesira
Hi Tesira,
Thank you for telling us.I have told this to our RD departments.Thanks.
Molly
Reallusion
Tesira
hi Molly, thanks.
Maybe also this could help. Two years ago AllanLee has answerd to my crash report:
"Hi Tesira,
Thank you for reporting this issue.
In fact, we have found this problem internally, but we haven't solved it yet.
The problem is more complicated, mainly because the function call between C ++ and Python does not allow any exceptions.
If there is any wrong code in RL's Callback function, iClone will crash.
So I suggest using Try / Expect in the Callback function.
We will continue to try to solve this problem.
Allen
https://forum.reallusion.com/428473/Tesira-is-learning-Phyton-with-iClone?PageIndex=6
Hi Tesira,
Thank you for telling me.I will transfer it to our RD.
Molly
Reallusion
Tesira
hi Molly,
well meantime I have tested again an easy demo script from the wiki, which also crashes iClone. I  have posted the result in the forum, that maybe also other can test it. So we can see, if this crashes only happen at my computer or also at others.
https://forum.reallusion.com/499281/iClone-crashes-with-Python-scripts
Tesira
Hi Tesira,
Thank you for you help.You're so nice.
Molly
Reallusion
Hi Tesira,
I will transfer it to our RD department.Thanks.
Molly
Reallusion
