Votes
0
Product:
iClone 7
Version:
7.72
Status:
Assigned
Issue 6734
One File Crashes iClone, no idea why
Hi!
I'm having a problem with one particular file, a scene with two characters animated with expressions, motions, and viseme/lip sync, but only an ibl for background, that keeps crashing iclone.
I'd saved several times, and everything was working fine, but then I started changing the ibl, it crashed, and now even the saved version (from before the ibl changes) crashes. Restore didn't work either.
iClone opens other scenes fine, even those with these two characters, so I *think* it's just this file that's corrupted, and normally I'd just shrug and recreate it, but I have a lot of expressions and motions that were so right for this scene, I'd hate to lose it all.
I've attached the suggested system information thing, but it's been at least two hours since the issue occurred--I have no idea if that affects what it will tell you or not. Also, I'm uploading the file that keeps crashing to my Google Drive to share if you want that, but my wifi is currently slow, so it
may be a while before I can share that.
Any suggestions?
Thank you!!
Nicole
OS: Windows 10
  •  8
  •  2800
Submitted by3DChick
1 2
COMMENTS (8)
3DChick
It worked! It worked! Thank you sooooo much!
I apologize again for missing Irving's message, but thank you, Irving and Molly for fixing this for me. The support here at Reallusion is leaps and bounds above any software I've ever used.
You guys rock.
PS: I rendered and uploaded it. It's just TTS for the speech and not the smoothest animation in the world, but I thought you might want to see it. https://youtu.be/jBuPOZuDTAE
Feedback Tracker Admin
Hi Nicole,
Thanks for sharing. That's a nice video.
We appreciate your kind words! Glad we can help :)
Irving
Reallusion
I'm glad to hear that.If you have other issue,please let me know.Thanks.
Molly
Reallusion
3DChick
Molly,
Holy cow,  I missed Irving's message on the 25th. I will try it right now!
Thank you for sending the reminder!
Nicole
Hi Nicole,
Can you try it with the hotfix version?
Molly
Reallusion
Hi Nicole,
Please apply the hotfix with the following steps, and see if it solve the problem:
1. Make sure your iClone has updated to version 7.73
2. Download “LargeProjectHotfix.zip" here: https://bit.ly/33M3DjO
3. Unzip the downloaded file to your local drive.
4. Move to the extracted folder, right click on “IC7LargeProject.bat” and select Properties,  check the Unblock box at the bottom of General tab.
5. Make sure iClone is closed.
6. Double click on “IC7LargeProject.bat” to apply the hotfix.
This hotfix will allow you to load the project file larger than 4GB and continue your work. Please let me know how it works out. Thanks!
Irving
Reallusion
3DChick
Irving--thank you so much for looking into this!
1 2
