Votes
0
Product:
iClone 7
Version:
7.71
Status:
Not Reproducible
Issue 6651
PNG Sequense with transparency creates artifacts
I can't export usable png sequense with transparency when i have glow enabled. It creates artifacts. You can see them when you play the sequence. They look like big squares semi transparent.
OS: Windows 10
  •  5
  •  1143
Bug
Submitted byahingel
COMMENTS (5)
ahingel
I dont have that file anymore
I had the toon shader enabled if that helps to identify the problem
Feedback Tracker Admin
Hi ahingel,
Can you provide project file to us?
Molly
Reallusion
Thank you for your feedback.
Please provide project file to help us identify the problem. Attach the file in your next comment. If the file size is larger than 10MB, you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment.
You can use Private Comment if you want to keep it private.
Your help is highly appreciated.
Molly
Reallusion
ahingel
yes i tried that too.  with the best render settings in general.
it happened to me before again but i didnt post the issure back then.
There is a render setting called "Include Glow Effect in Alpha". Did you try that?
