Votes
0
Product:
iClone 6
Version:
6.53
Status:
Active
Issue 853
Please upgrade the Indigo Plug In to use more than 1 core for export
Hi,
Please can you upgrade the Indigo Plug In to use more than 1 core for export. As it exports a frame at a time, therefore it should be able to export more than one frame at a time without trouble using multiple cpu cores. Having a number of cores option (or slider) would speed the export dramatically for production scenarios.
Please can you add?
Thanks,
Jonathan
OS: Windows 10
  •  1
  •  2874
Submitted byjrdm
COMMENTS (1)
info_20090922174604841
I find that IClone uses all the cores on my system to export an Indigo sequence. However Iclone is very frugal when comes to the use of the gpu. That said this is the least of my problems pertaining to the Indigo plug, at least for myself. It would seem that on my system, Iclone uses every bit of ram as it builds a sequence and retains it in ram. This results in a IClone crash before it can finish a sequence. The higher the frame size the fewer the frames before crashing. To date 20 frames at 1920x1080 at 60fps is the top record I have. Myself I have Indigo on a separate machine that renders Indigo images as needed allowing me to work uninterrupted.
