Votes
Product:
iClone 7
Version:
7.4
Status:
Active
Issue 5553
Problem with DOF
Even with high quality dof and supersampling the blurred background its not coming out smooth.
Weird square shapes/lines or spots appear.
OS: Windows 10
  •  3
  •  1632
Submitted byahingel
COMMENTS (3)
Dragonskunk
Confirmed!
Problem using DOF, the part that is blurred is full of strange artifacts on the most blurred section.
This occurs when you use a material in the scene that has refraction. Without, there are no artifacts.
This iProject crashed as I was making it so I can't delete the props that start with the letter "W" therefore the zip file is 57megs.
zip with iProject:
http://www.filedropper.com/baddof_1
Feedback Tracker Admin
Hi Dragonskunk,
I have got your file, we will check this issue.
Thanks for your help.
Reallusion
ahingel
unfortunately i didnt save the project. Maybe the problem occured because i was using smoke or fog almost everywhere in the scene.
Hi ahingel,
Please provide your project file to help us identify the problem.
Attach this files in your next comment. If the file size is larger than 10MB, you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment. You can use Private Comment if you want to keep it private.
Your help is highly appreciated.
Reallusion
