Bei einer Erzeugung einer AccuRig hängt sich das Programm im Punkt Bind Skin bei 18 % auf und lässt sich nur noch beenden. Das habe ich mit verschiedenen FBX Dateien und auch OBJ Dateien sowohl in Blender wie auch in 3DAI Studio bearbeitete Dateien versucht. Was mache ich falsch?
Hi Michael Schmich,
Could you please provide the model files (FBX/OBJ) that are causing the issue?
If possible, it would also be very helpful if you could share a complete screen recording showing the steps to reproduce the problem as well as cc project. This will help us investigate the issue more efficiently.
You can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment. You can use Private Comment if you want to keep it private.
Thanks
Steven
Reallusion
You are going to edit a submitted issue. This issue will be changed to private draft mode until you click submit again. Are you sure?
