Votes
0
Product:
iClone 8
Version:
8.33
Status:
Released in 8.4
Issue 10934
RIFacialDevice.ProcessData seems to be broken in 8.33
RIFacialDevice.ProcessData seems not to work any more, and it doesn't return any errors either.
The script in this post can be used to reproduce this problem,
https://forum.reallusion.com/523684/How-to-write-a-facial-mocap-plugin
OS: Windows 11
  •  4
  •  681
Bug
Submitted bysunnyviewtech
COMMENTS (4)
sunnyviewtech
Thank you for the help, we will fix our plugin accordingly!
Feedback Tracker Admin
Thanks. I will close it.
sunnyviewtech
Hi, we have got it working successfully! Please close this issue, thank you for your help.
Hope to solve your problem!
Molly
Reallusion
Hi sunnyviewtech,
The sample code didn't account for different numbers of expressions for characters, which caused some errors.
We've updated the Sample Code, so give it another shot!
Molly
Reallusion
sunnyviewtech
Hi, you can check the AppData\Local\Reallusion\RLDownloads folder to see if the previous versions are still there
CYBL
Is there a way to roll back to a previous version while this is being looked into. Since I can't run MotionLIVE in the webcam at the same time as the plugin, I am currently stuck without any facial capture.
