Votes
0
Product:
iClone 8
Version:
8.52
Status:
Active
Issue 11670
Redering no longer works
In version 8.52, the textures are no longer loaded during rendering. This did not work before. The error was fixed in version 8.51. Now it is there again.
OS: Windows 10
  •  3
  •  382
Bug
Submitted byHanniB
COMMENTS (3)
HanniB
Unfortunately, the problem has still not been solved. To this day, I can only make renderings with great difficulty. After loading characters saved in CC, but also for projects saved in IC, the textures are still missing after reloading during IRAY rendering.
The problem can currently only be solved by saving the materials for all objects (save material plus) and loading them again (load material plus). This is very time-consuming.
Can you offer me a solution or let me know when the error will be fixed?
HanniB
I have been able to limit the problem somewhat. If I create an actor in cc4.52 and do an iray rendering it works. If I then save the character and load it again, the textures are no longer loaded during the iray rendering. If I then change the material parameters, it works again.
The same problem exists with iclone8.52. When I load an actor, the textures are missing in the iray rendering. If I save all textures as materialplus and load them again or change parameters, the iray rendering is correct.
Feedback Tracker Admin
Hi HanniB,
I can repeat it.Thank you for your help.
Molly
Reallusion
Hi HanniB,
Can capture a screen video about this issue, put it on the YouTube, and add the link in your next comment?
Molly
Reallusion
