Votes
0
Product:
Cartoon Animator 4
Version:
4.5
Status:
Duplicate
Issue 7987
Repeated failure!
The program crashes as soon as it starts, impossible to load anything, neither scenes nor characters nor anything. I have reinstalled it several times, even clean installations and it does not work !!!, in the end I had to install the previous version that if it works, it is not stable at all but at least I can do something with it. It is by far the worst version of this program, and I have been with you for many years !!
Also, impossible to update the cartoon resource pack
OS: Windows 10
  •  5
  •  3124
Submitted bydioxo
COMMENTS (5)
Feedback Tracker Admin
Hi dioxo,
You can get the Resource Pack installation from the link below:
https://www.reallusion.com/linkcount/linkcount.aspx?lid=CA4en31
Allen
Reallusion
dioxo
one more
dioxo
more of the same problem ...
dioxo
After updating everything, both windows 10 and the video card drivers, the following results:
If the content is loaded from the windows explorer by dragging and dropping, and previously closing the content window it works perfectly, it loads the contents without hanging.
But, if you try to activate the content window (f4), the program stops working (I imagine it must be related to the content thumbnails).
Attached I send you the file RL_FBT_UserSystemInfo_Windows
Thank you for your feedback.
Please try the below ways to see if the problem can be solved:
1) Go to the Start screen, type & search Windows Update. Then select "Check for updates" from the search list to check & install all important updates.
2) Update your graphic card drivers to the latest version.
- ATI: http://support.amd.com/en-us/download
- nVIDIA: http://www.nvidia.com/Download/index.aspx?lang=en-us
- Intel: http://downloadcenter.intel.com/
If there is still problem, please refer to the below link to provide us the RL_FBT_UserSystemInfo_Windows.zip file to let us check your system environment:
http://www.reallusion.com/FeedBackTracker/Home/HowToGet
You can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and add the link in your next comment. you can use private comment if you want to keep it private.
Allen
Reallusion
