Votes
0
Product:
iClone 8
Version:
8.31
Status:
Assigned
Issue 11194
SBS Render Bug
Hello,
Windows 7 Pro 64 /32GB Ram, not tested on Win10
- New Project
- Import Obj (zip inluded)
- Click "Home" to center Object
- Press F3, turn Object ~360 degrees like in inluded project
- Click render, Select 1920x1080, Select Stereoscopic, Select SBS
- Render Mp4
-- Result see inluded mp4
Not shure though if this a user mistake or something wrong with this specific obj.
When importing the obj it appears very small and not centered originally.
OS: Windows 7
  •  3
  •  509
Submitted byK_Digital
COMMENTS (3)
K_Digital
When lowering  Interocular Distance the view indeed changes slightly but i doubt 1.0 for example is a real world distance.
After some testing , It appers this error only happens when an object is "too small". I made the object 30 times larger with CC4.32, created a new project as described above,
rendered to SBS without issues. So i assume the Interocular Distance may be not correctly calculated when an object is very small.
Please compare the difference in size of both obj in the zips provided. The first one may be too small for proper use with this function.
Hope this helps
Regards
Rolf
Feedback Tracker Admin
Hi K_Digital,
I have transfer to our RD department and hope they can find out the reason.Thank you for your help.
Molly
Reallusion
Hi K_Digital,
Can you change Interocular Distance and try it again?
Molly
Reallusion
Hi K_Digital,
I can't repeat it with your project,but when I change Interocular Distance in Render menu,it will happen.Please change Interocular Distance and try it again.Thanks.
Molly
Reallusion
