Votes
0
Product:
iClone 7
Version:
7.41
Status:
Active
Issue 5897
Scaling issue of saved animated Prop . . .
This is getting ridiculous. Same Project file, 913Mb. I create an animated wheel using a Dummy object as shown, a cube. I add that Prop to my Props so I can drag-n-drop another copy into the Scene. When I do this, as the picture attached shows, the animated wheel is "scaled" out of proportion and is now larger than the stupid room it came from.
So, once again, I have to either: rescaled the wheel or select it again and drag it to the place I need it. That, then, becomes another problem as the Perform I added to this wheel goes out of whack and tries to go back to it's original location. I removed the Object animation, but when I hit Perform, you can see the wheel slowly move back to it's original location.
Again, another "problem" that has created another "problem". It is possible that you guys can add a "Lock" checkbox next to each Axis so you can stop it from moving in the wrong direction(s)?
OS: Windows 10
  •  5
  •  1531
Submitted byTucsonDoobie
COMMENTS (5)
TucsonDoobie
Molly,
Sorry. Unable to comply.
Thanks!
...dave
Feedback Tracker Admin
Thank you for your feedback.
Can you provide the prop file to us?
Molly
Reallusion
TucsonDoobie
Molly,
BTW, this is a DAZ prop from their "ELECTIC INTERIOR LAB". I used 3DXChange 6 to break it apart, i.e., the wheel, so I could animate it. I duplicated that "wheel" after I added a Perform function on this new iClone prop. I added it to my Prop library. When I dragged the prop into the room, it scaled all by itself.
...d
TucsonDoobie
Molly,
It might be a while as I'm in production of a PREVIEW.
...d
Hi BeeFlowerPower,
Please provide the prop file to help us identify the problem.Attach the file in your next comment. If the file size is larger than 10MB, you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment.
You can use Private Comment if you want to keep it private.
Your help is highly appreciated.
Molly
Reallusion
