Votes
0
Product:
Character Creator 3
Version:
3.2
Status:
Closed
Issue 6467
Skin Weight on only a part of the clothes
Hi,
I have an issue and I can't find the solution online. I have a character with an imported grand coat. When I transfer the Skin weights, it transfers for all the coat. As you can see in the picture I have attached, this is not how the coat should behave, as the bottom of the coat should not move if the leg moves. I'd like to completely remove the skin weight of the bottom of the coat but I haven't managed to do that.
I tried to adjust Skin Weights manually of the coat, but it doesn't work and the coat keeps following the leg. Everytime I try to set the weight of one bone to 0 for the bottom of the coat, another bone that I changed previously to 0 changes to some value without my input. So that doesn't work.
I would really appreciate the help.
Thanks a lot,
OS: Windows 10
  •  3
  •  1378
Submitted byDonPoko
COMMENTS (3)
DonPoko
That worked perfectly thank you so much !
Feedback Tracker Admin
Hi fiesta96,
Is this issue still bothering you?
Please let us know if the solution worked!
Thanks for your help.
Calvin
Reallusion.
Hi fiesta96,
Thanks for your feedback!
You can bind those vertices' skin weight to Hip bone, and try to see if this work for you!
Calvin
Reallusion.
