Votes
0
Product:
iClone 8
Version:
8.41
Status:
Active
Issue 11330
Soft Skin Physics, Full IK chain compatible with Sprint Joints + *Full body* Morph/Cloth Tracking like beards + Ragdoll Physics
You may have heard Unity Acquired Ziva for an undisclosed amount some time after financial backing of ***7 MILLION DOLLARS*** in seed funding https://youtu.be/CMfSqZdj5KU?t=577 Bringing a more simplified and available solution to Reallusion and users, I feel rich and somewhat robbed (just the idea that it's worth so much to professionals and it seems I could be too in this case)
I never knew Ziva existed until today. Between all the tech I've demonstrated to Reallusion and it's potential with skin physics, spring joints for arms where IK would normally be + custom eye & tongue joints (also should be ik) Reallusion could still tap the potential with it's own seed funding if needed but as I've said before, you're sitting on a gold mine if you were able to focus on this development, I know how templates could be made to make it easy for customers so they don't have to do everything from scratch but my time is worth a lot, I've already given you some of the major game changing ideas, pointed out the obvious - worth millions, likely I'm in there too, I don't want to come across arrogant/rude although it might sound like it at times.
Lastly, combining the above with multi body part cloned joints of arms, jegs, heads etc, to be able to switch to them to mocap individually would be mind blowing.
In terms of fixing Displacement seam ripping, the easiest solution might be to create a special AI UV Projection (no UV seams) This way even the physics weight maps can have flexibility anywhere without worrying about the material boarders (I currently have to pin them otherwise materials can separate from each other)
OS: Windows 11
  •  2
  •  529
Submitted byAscensi
COMMENTS (2)
Ascensi
Private Comment
Ascensi
Also FYI, both Omniverse and UE5 are still trying to figure out how to create this effect, and I created it with YOUR software a few years back.  -a solo creator rather than multiple engineers. Another example of my soft skin physics https://www.facebook.com/reel/350351257950402
You are on the cutting edge, a gold mine, your system is already operational but needs a few tweaks. I hope you've already been working on it, if not I hope this information helps you take my advise and examples more seriously.
