Votes
0
Product:
iClone 7
Version:
7.82
Status:
Assigned
Issue 7413
Some bugs and Suggestion
I found some problem. I made a video with 19 suggestion. https://www.youtube.com/watch?v=noN16ze1les
OS: Windows 10
  •  4
  •  2107
Submitted byFreddymusic
COMMENTS (4)
Freddymusic
issue 2
Of course it is works. It is not a bug, just a recommendation becouse if i have too much attached object some times would be better a solo button.
issue5
Maybe i was wrong with it. I try to explain. i have an audio file in viseme track. I cut it and i delete the cutted second section.  After delete i can't back to the original just only if i remove the complete audio from the track and i drop the audio again into the sound track. Why bad it? If i changed the lip sync in a lot of point and yet I want to use the cutted and rewmoved slice my only option to undo every editing or remove it and drop it again. But if i drop it again, i will lost the lips modifications.
issue6
I rendered it in 1920x1080 in uncompressed avi. so it is not solution.
Issue7
i will try it in a next time.
issue13 solved.
Freddy.
Feedback Tracker Admin
Hi Freddymusic,
I have got it.Thanks.
Molly
Reallusion
Freddymusic
Issue 4:  Audio now in the attachment. I have a BPM metadata in the Wav file, i don't know is it the problem, or not. But i made this wav with Presonus StudioOne 4 Pro.
Issue6: If i uncheck Correct Transparency i lost the Depth of field settings and i cant reproduce the original concept without this function.I send the project file with this link and you will see what is the problem. : http://www.tbklub.hu/bitsonic/depth_of_field_problem.zip
Issue4
Can you provide the audio file to us?
Issue6
Can you uncheck Correct Transparency,and try it again?
Molly
Reallusion
Issue5
You mean that you break one audio file ,delete the second viseme clip,then edit lips key,but you want to go back the original audio.If you undo or import audio file again,you need edit lip keys again?If yes,I suggest that you break viseme clip after you edit all lip keys.
Molly
Reallusion
Issue4
Issue6
Please go to Preference panel,uncheck Correct Transparency,and try it again.It works for me.
Molly
Reallusion
Hi Freddymusic,
Did you provide your audio file in the fourth issue?We will fix some issue in next version,we need your audio file to check if the reason is the same.
Issue 2:
You can press Ctrl multi selected several objects and set show/hide.
Issue5:
I see the icon is Resize,so you can't loop voice clip.Please go to Timeline Toolbar and press Loop button,try it again.
Issue6:
Please render video with Output Size 1920,and does it still happen ?
Issue7:
Did iClone crash when you new project in empty project?Please provide crash dump file to help us identify the problem.You can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment.
Download the zip file with the link below, inside the zip you can find the description about how to generate the startup log and crash dump.
https://drive.google.com/file/d/10LLfXMh94JEFT2CK4hD9ejpsuzwnAq7l/view
Issue13:
Please press Ctrl + P,open Preference panel,go to Control section,check Sync Template and Custom Category.It will keep same folder when you change Template and Custom.
Molly
Reallusion
lianchiu
issue 13
Hi Freddymusic,
Thank you for your feedback.
Below is a short summary of your suggestions,
1.[SceneManager] Tabs layout is not saved
2.[SceneManager] Group show/hide will be easier for multiple objects
3.[SceneManager] Parent show/hide breaks child's visible state
4.[Timeline] Split clip on the sound track does not work, no sound after splitting
5.[Timeline] Voice clip cannot loop after break
6.[DOF] Character's eyes do not blur in background
7.[New Project] New project sometimes cause AP to crash
8.[Content] Incorrect scale behavior in some components of "Star Ship Component Kit"
9.[Mini Viewport] Window is too small, request to maximize the window size
10.[DOF] Request more bokeh types
11.[Motion Layer] Ability to enter precise value for bone rotation
12.[Motion Layer] Unexpected IK behavior after character scaled
13.[ContentManager] Change Template and Custom won't keep folder selection, e.g. Prop
14.[Transform] Request bigger value for object's scale, 9999.99 is not enough
15.[Shadow] No shadow for the object with opacity value smaller than 20
17.[Content] The texture of IS-Sky HDR-Blue2.iprop is not HDR format
18.[Timeline] Audio cannot directly drag & drop to Viseme track, too many unnecessary click
19.[Timeline] Cannot split clip on its first frame (Viseme)
Next time, if you could submit your suggestions to separated issues instead of grouping multiple suggestions into one issue, it would be much appreciated. This will help us track issues on FT more easily.
Thanks!
Irving
Reallusion
