Votes
Product:
iClone 7
Version:
7.61
Status:
Active
Issue 6250
A problem when I make Custom motion and FBX exporting
As the title suggests, the animation output after custom motion and FBX export is not the same as what I was working on. Especially in the upper body, the phenomenon is noticeable, and all parts of the head, waist, chest, arms, etc. come out differently than before storage.
I found this to be due to the 'Bake constraint key' function.
If you use 'link' as a props for your character and save or export it, you will get the above error. Even if you use the 'link' function and then unlink it immediately, you get the problem. The way to avoid this problem is to not use Contstraint. But I can't change the direction of the motion clip. Please let me know if there is another good way.
I used this 'link' function to change the direction of the moving character. I put a box on my foot and used it as a rotation axis to change direction more naturally.
I hope this solves the problem.
After writing this article, I found that the animation still changes in FBX export. As I checked in Unreal, it was a small change, but the neck was different. I don't really know how to solve this.
OS: Windows 10
  •  3
  •  1711
Submitted byaixlab
COMMENTS (3)
aixlab
I follwoed but the result was same.
When I didn't add a key for Constraint, it is changed very slightly but it's OK. almost same.
I didn't check about exporting FBX for Unreal.
But I think if there's a key for Constraint, The result may be different from the original.
Feedback Tracker Admin
Hi aixlab,
Can you tell me the result?
Molly
Reallusion
Hi  aixlab,
Please don't check Reset Motion Root in Modify Menu,then apply motion. Try it again.
Molly
Reallusion
