Votes
Product:
Character Creator 4
Version:
4.02
Status:
Active
Issue 8811
Stop Automatically triangulating imported meshes
I do not model in triangles specifically because quads make weight painting easier than triangles, but every mesh that I import is automatically triangulated in CC4. This and the automatic Tesselation make it difficult to accurately weight paint in CC3. Because it's triangulated, you can no longer select loops which makes weight painting way more difficult than necessary. I would like to suggest that when a model is being imported, that you leave it in quads, whereby you can use loop select to help make weighting easier. Once the weight painting is done, you can add a finalize step which then does the triangulation needed.
OS: Windows 11
  •  1
  •  677
Submitted bywill2power71
COMMENTS (1)
Ascensi
I second this. Adding extra verts slows everything down. I'm used to working with akeytsu in part because it's 2-3 times faster, it uses quads while in weight paint mode.
