Votes
Product:
iClone 7
Version:
7.3
Status:
Active
Issue 5329
Substance texture on the object in ic7.3.2205.1 is not visible.
Substance material on the object in ic7.3.2205.1 is not visible.
only when I press button substacce texture baking. then the texture can be seen on the object
I tried this on 2 different PC, no success
OS: Windows 7
  •  6
  •  3208
Bug
Submitted byBarran
1 2
COMMENTS (6)
Barran
Thank you Reallusion Admin. I did not know where to write.
Iclone is a great work and I love it.
and so I close this message
thanks again
Feedback Tracker Admin
Hi Barran,
Please Open Preference panel, and confirm if Substance is check? If not, you can't see substance material on object.
Reallusion
Barran
Yes, thank you wires. I do not ask why it works for you.
But why does not work in my Iclone.
Is there anyone with the same problem? Is there a solution for this?
I'm using the same version on Win 10 and still can't reproduce the issue - see screen shot
Barran
thanks wires for your answer.
I write about the new version of iclone 7.3.2205.1
I did not have that before the update.
here the attached screen shot under windows 8.1
1 2
