Votes
0
Product:
iClone 7
Version:
7.3.2205.1
Status:
Active
Issue 5489
Tessellation & Displacement - New undocumented workflow
I've struggled with setting up displacement textures generated by 3DCoat to work in iClone 7. The workflow presented by Reallusion's tutorials/doc only seemed specific to displacement examples iClone provides but in general tessellation and displacement settings are in iClone are scattered/almost hidden if you don't look hard enough. I saw a video tut by https://youtu.be/HcM42FdOtPs and it didn't work for my 3DCoat exported textures . If I just use tessellation the model will appear cracked and sliding the displacement strength just looses the displacement details.
I've been working with 8k photo scanned textures and to make the model appear solid & clear/cleaner looking displacement I would recommend NOT using the tessellation slider by itself, either set to 0 or additionally go to modify, attribute tab, set the smoothing option to subdivision to 1-3 then slowly ramp up tessellation to what looks best.
I'm suggesting to put everything to do with displacement in one area or at least put the mesh smoothing/subdivision in the materials area as well under the tessellation field and or update your workflow with this information.
OS: Windows 10
  •  1
  •  1549
Submitted byAscensi
COMMENTS (1)
Ascensi
I'm updating this for others. When your model doesn't have enough geometry or isn't properly welded it will split at the UVs. The quick solution if you aren't a modeler is to use smooth mesh by subdivision level 1 and set tessellation to level 2. Warning  Iray is apparently not yet compatible with smooth mesh by subdivision and could take days or weeks to output 15 seconds.
If you are a modeler test the resolution of your geometry before painting it. For example if in Zbrush, create your ideal model/shape and although keeping it low poly you might be 1 subdivision level away from allowing the UV seams to snap together properly in iClone.. so test your displacement maps on a subdivision level higher than the previous.
