Votes
0
Product:
iClone 6
Version:
6.5
Status:
Hold
Issue 526
The character will move backward if stop the recording for motion clip on Direct Puppet panel
STEPS TO REPRODUCE
1. Launch iClone 6
2. Apply a random CC character (e.g. Christian), navigate to Modify > Edit > Transform > Move, set Z to 150
3. Apply a random prop (e.g. Arc_001), navigate to Modify > Edit > Transform > Move, set X to -300, Y to 300
4. Right-click the character and select Link > Link To, link the character to the prop, then go to Frame 200, pick the prop, navigate to Modify > Edit > Transform > Move, set Y to 200
5. Go to Frame 1, pick the character, navigate to Menu > Animation > Direct Puppet, then select the Effector of Dummy's head
6. Go to Puppet > Rotate, select “Screen-based (4)”, then click to record motion clip and press Space to stop
7. Check the character's position
ACTUAL RESULT
The character moved backward
EXPECTED RESULT
The character should stay in the same place
OS: Windows 10
  •  1
  •  2733
Bug
Submitted byFeedback Tracker Admin
COMMENTS (1)
Thank you very much for your attention.
An alternative workaround is to unlink the character, complete the steps of Direct Puppet, and then relink the character to the prop.
Reallusion
