Votes
0
Product:
iClone 7
Version:
7.83
Status:
Assigned
Issue 7470
Timeline Issues
when you hit shortcut A on timeline doesnt create keyframes anymore
and when you hit the delete button with selected keyframe deletes the whole character not just the keyframe
OS: Windows 10
  •  4
  •  2115
Submitted byahingel
COMMENTS (4)
ahingel
ah sorry
its working when i press A on gesture layer (its not working on Lhand/Rhand)
Feedback Tracker Admin
Hi ahingel,
It can't be allowed to add key in Gesture RHand & Lhand track.It should be disable.If you want to add key,please open Edit Motion Layer panel,the key will be set in Motion Layer track.
Molly
Reallusion
ahingel
its not working on gesture layer now
neither on l or r hand
ahingel
i tried it and it wasnt working on the motion layer track and transform layer. I didnt try it on the gesture layer
But i just tried it again to answer you for sure, and it worked fine now...
did you update it?
ahingel
yes A hotkey is also working now
Did hotkey A also work?It works in my iClone.
Molly
Reallusion
ahingel
yes if it happens again i will tell you more details
thank you
Hi ahingel,
It happens randomly.If you can repeat it everytime,please let me know.Thanks.
Molly
Reallusion
Hi ahingel,
Thanks for your feedback.
Which track did you edit by pressing shortcut A?
If you select the Transform, Gesture, or Motion Layer track, this shortcut should be work.
Then, if you have a workflow about deletes the whole character, like what track which your deleted keyframe on.
It will be helping us.
Melvin
Reallusion,
