Votes
0
Product:
iClone 8
Version:
8.52
Status:
Not a Bug
Issue 11832
Timeline Loop confusing or not working as epected
I understand the Loop timeline function, see image, as a loop that can be played repeatidly beet ween two marker points.
When selecting Loop "export" iclone plays from the first to the second marker, then stops.
When selecting Loop "previev" iclone plays from the first marker to the very last frame of the project, then stops.
IIRC in an earier version of iclone this worked as expectected.
OS: Windows 10
  •  3
  •  485
Submitted byK_Digital
COMMENTS (3)
K_Digital
Ok, in my project the right yellow marker was hiding behind the modify tab and not visible which probably caused the confusion.
Please ignore my report, its clear now that the green markers are for export, the yellow markers for preview loops.
They both work perfectly !
Feedback Tracker Admin
Hi K_Digital
Thank you for your feedback.
I'm not sure if your Timeline has the "Set Start / End Frame" feature. After you press the Set button, the markers for the "in" and "out" positions in the Preview will appear, and after playback, the loop function will work properly.
I'm not sure if I have been of any help to you. :)
Kayla
Realluison
K_Digital
Please do not be confused with timeline and play bar Loop. Above i meant the Loop Button in the play bar isn working as intended.
