Unable to create a Male Character, All inputs provided were Male the final output was a female, I am using a trial version currently to test my needs
Unable to create a Male Character, All inputs provided were Male the final output was a female, I am using a trial version currently to test my needs. Unfortunately, not sure if its under female default. its a straightforward test , Male imputs using HEADSHOT 3 should generate the final Output as Male , but its female and its not working . The Load CC5 HD Neutral Base loads a female as well.
Hi pragrajaram,
Could you please describe the issue in more detail? If possible, it would be even more helpful if you could provide a complete screen recording of your workflow.
This will help us accurately identify the root cause of the issue.
Thanks
Steven
Reallusion
You are going to edit a submitted issue. This issue will be changed to private draft mode until you click submit again. Are you sure?
