Votes
Product:
iClone 7
Version:
7.3
Status:
Active
Issue 5285
Viseme track affects mouth past its own range
If there are frames before the audio for speech and the first phoneme has a keyframe that opens the mouth, then the mouth will slowly open until it reaches that first phoneme.
You have to keyframe every first phoneme with a NONE type keyframe to prevent this.
What should be corrected is the mouth must not be affected by any viseme that is not in the range of the sampled audio.
OS: Windows 10
  •  2
  •  1405
Bug
Submitted byDragonskunk
COMMENTS (2)
Dragonskunk
Attached is an example of this bug.
You can see the mouth stays open from frame 1 till it gets to the viseme track and stay open when it is past the track. The second viseme track I added NONE at each end and then the character viseme track which allows a closed mouth before and after.
Feedback Tracker Admin
Thank you for your feedback.
Please provide your project file to help us identify the problem.
You can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and email the link with "FT5285" in the email title to feedbacktrackeradmin@reallusion.com.
Your help is highly appreciated.
Reallusion
