Votes
Product:
iClone 7
Version:
7.4
Status:
Active
Issue 5531
Where is the SOUND PANEL?
The Project panel in iClone 7 does not show any of the Sound files that might be in a project.
I've added a heart-beat, but now I can't find it anywhere. The only way I know how to find it is to select every object, one-by-one, until you happen to see the file attached to a prop or character, for example. That becomes very painful if you have a lot of objects in the scene.
There should be a completely separate integrated panel for Sound. Don't make it a pop-up as these kinds of windows get in the way. As I have CS4, I've had to keep my resolution to 1920 x 1080, otherwise when I run Photoshop, for example, I get 3 cursors instead of one. (:o)
OS: Windows 10
  •  1
  •  1937
Submitted byTucsonDoobie
COMMENTS (1)
It would be nice to have a EASIER WAY TO FIND ALL AUDIO in a project.
Meanwhile, here is an approach several people use:
1) Add a DUMMY OBJECT to you scene.  It will not appear when you render.  One for each sound clip.
2) Drag your sound clip onto the dummy object.
3) Rename the dummy object in your "Scene" listing.  Example:  Heartbeat... gunshot... squeaky hinge... etc.
