Votes
Product:
Character Creator 4
Version:
4.53
Status:
Active
Issue 11987
Wireframe not showing in skin weights mode
When entering skin weights mode the wireframe is not visible when setting the Display Weight to Color Weights (see attached image). I obviously need to be looking at the wireframe, as well as the color weights as im skinning a mesh. I tried turning the wireframe mode on and off but nothing changes. A couple of additional notes that might help troubleshoot this:
The problem only occurs in skin weights mode. I'm able to see the wireframe of a mesh normally outside of this mode.
The wireframe in weights mode is vaguely visible in an offset position from the mesh (screenshot attached).
This might be a local issue, since we weren't able to re create the problem in different PCs using the same project file. It only happens on my PC.
The same issue occurs when loading any avatar, mesh or project file.
I tried uninstalling and reinstalling and the issue still exists. There might be some specific folders that need deleting but I'm not sure where those are located.
I hope this is enough information.
OS: Windows 11
  •  9
  •  1014
Bug
Submitted bynikolaospoulianitis
1 2
COMMENTS (9)
Feedback Tracker Admin
Hi nikolaospoulianitis & Nehon
Could you please provide us with your system information once again?
We have an updated information link, and we would like to request the latest details from you.
https://www.reallusion.com/FeedBackTracker/Home/HowToGet
Kayla
Reallusion
Hi Nehon
We sincerely appreciate your assistance.
Our team will investigate and clarify the issue as soon as possible, and we will work diligently to resolve the matter and address any inconvenience it may have caused you.
Thank you again for your patience and understanding.
Kayla
Reallusion
Nehon
Hello, here are my system info.
Note that the issue doesn't happen all the time, sometimes it works just fine. I couldn't find what causes it.
Anyway, don't worry, not a deal breaker.
Thank you for your patience and support. Our team has clarified most of the operational procedures. However, we would like to further confirm some details and kindly ask you to provide the system information to help us proceed with a more in-depth investigation.
Also, we sincerely apologize for the delayed response and any inconvenience this may have caused. We appreciate your understanding.
KaylaYang
Reallusion
Nehon
Hello, I have the same issue. I tried what's advised in this post, however it didn't work, well not as it should at least.
When I select "wireframe on shaded" I can indeed slightly see the wireframe, but it seems shifted
see the picture .
I tried to apply the transforms in blender, but it didn't help.
1 2
