Votes
0
Product:
Character Creator 5
Version:
5.11
Status:
Closed
Issue 12656
Zbrush Face Tools does not export to Zbrush. Errors at Zbrush.
Doesn't matter what character I use in CC5, It will not make the transfer to Zbrush Face tools anymore. I get the following error messages (attached items)
-Missing wrinkle config json path
-SCRIPT: FaceTools.txt
ERROR: Tool:Layers:New
IN: [IPress, 'Toll:Layers:New']
And then if I try to hit Refresh Face Tools I also get a following SubTools are missing error. I've attached everything below.
I looked through some other bug reports that said check if you have a WrinkleGoZConfig_Advance.json file and as you can see in my attached screenshots I definitely do.
I am using CC5 and Zbrush 2022.0.8 which used to work with CC5.
OS: Windows 11
  •  5
  •  107
Submitted bychristopherpaulparks
COMMENTS (5)
ChengJhong(RL)
5.12 has changed the location of all plugin for  zbrush. And I guess the error may be the .txt that zbrush is using is an older version.
That seemed to do the trick. I also tried CC 5.12 when i tried this. I'm not sure which one fixed it but it's good advice either way. Thank you.
ChengJhong(RL)
Have you tried deleting the ZBrush Plugin and reinstall FaceTool?
Also delete everything under Reallusion\ZBrushData.
Seems wierd that this message show up because the process should be removed.
Yes I know what refresh face tools does. I was only giving additional information, sorry for the confusion. The obvious issue is that I cannot send CC5 to Zbrush with Zbrush Face Tools. That's the real issue.
ChengJhong(RL)
Refresh facetool is used for startup with loading .zpr or .ztl in ZBrush if you have send from Character Creator before, the function isn't same as goz plus.
It shall work if you're sending data from Character Creator. I'll check if missing any other settings.
