Votes
0
Product:
iClone 7
Version:
7.73
Status:
Assigned
Issue 6770
cant load my project
hello,
i saved my project without bugs/errors. next day when i open in 70% loading stream iclone give me messege "Failed to lad the file".
could you help me?
i used unreal live link also
OS: Windows 10
  •  5
  •  1988
Bug
Submitted byprzemyslaw.piekarz
COMMENTS (5)
long842672
I also had the same problem. I have followed the instructions above with no success. Here is my file, please help me ( https://drive.google.com/file/d/1joQHuCS3K4KaSm3ehMewCySOXU9ZJ6fL/view?usp=sharing
Feedback Tracker Admin
Yes,there is no folder containing a cache restore file
long842672
You mean there is no folder containing a cache restore file in case iclone crashes,I don't know if I've expressed my wishes exactly to you
There is no way to restore.
Molly
Reallusion
long842672
I mean, asking where to save the recovery file, but without clicking ok, I think there will be a cache.
Hi long842672,
Usually when iClone crash,you launch iClone again and will ask if you want to restore.I'm very sorry that your project has been broken,it can't restore.
Molly
Reallusion
long842672
please let me know where to save the recovery file when i have trouble stopping iclone suddenly
Hi long842672,
Although there is no error,your project is already broken before saving.So you render fail and can't load it.We hope to know what you did before saving.
Molly
Reallusion
long842672
I work normally on the project, it doesn't have any errors until I render it unsuccessfully
Hi long842672,
I mean what you did before saving project,if you can remember,maybe we can fix it and the error won't happen again.
Molly
Reallusion
long842672
After this file, I save it to render, the error stops suddenly, restart the computer with the file error as above.
Hi long842672,
I'm very sorry that your project file is broken,we can't save one to you.Did you remember what you did before you save your project?
Molly
Reallusion
przemyslaw.piekarz
Hi,
others Projects works properly. I'm sure that was problem with saving, because similar project with same characters without animation is 1,2 Gb and this is only 400 mb
Hi przemyslaw.piekarz,
Project is here.
https://drive.google.com/open?id=1D8v0iAIIHxgytvij_kqvvH0NSBMuTLI5
Molly
Reallusion
przemyslaw.piekarz
Hi Reallusion,
it will be very helpful :)
If you want to use it urgently,I can ask RD to save the project that can load to iClone.
Molly
Reallusion
przemyslaw.piekarz
Hi Reallusion,
any information from RD department?
Regards,
Przemek
Thanks very much.
Molly
Reallusion
przemyslaw.piekarz
Hi,
i added 3-4 Mixamo characters to my project vis 3dXxhange. Some camera works. that's all
Did you remember what you did before saving project?We hope to know the reason.
Molly
Reallusion
Thanks.I have transfer it to our RD department.
Molly
Reallusion
I have got it.Thanks.Can't you only load this project,or any project after saved?
Molly
Reallusion
przemyslaw.piekarz
hello,
unfortunatly this Project  is less than 4GB. I sent you link to google drive at 11 April with title "Issue 6770".
thanks in advance,
Przemyslaw Piekarz
How large is your project file?
If the file size is larger than 4GB, please try the following hotfix and see if it works:
1. Make sure your iClone has updated to version 7.73
2. Download “LargeProjectHotfix.zip" here: https://bit.ly/33M3DjO
3. Unzip the downloaded file to your local drive.
4. Move to the extracted folder, right click on “IC7LargeProject.bat” and select Properties,  check the Unblock box at the bottom of General tab.
5. Make sure iClone is closed.
6. Double click on “IC7LargeProject.bat” to apply the hotfix.
If the file size is less than 4GB or the hotfix not working, then we will need your project file to investigate what was going on.
Could you provide your project file for us to check?
You can upload it to any cloud storage, e.g. google drive, one drive. Put the file link to the next private comment.
We are sorry for the inconvenience and hope it can be sorted out soon.
Irving
Reallusion
