Votes
0
Product:
iClone 7
Version:
7.3
Status:
Released in 7.3.2205.1
Issue 5345
cloth simulation does not render correctly when rendering a frame sequence.
I have a simple falg attached to an object that renders correctly in a preview mp4 but does not simulate at all when i render a frame sequence.
Bythe way please do fix the bug that i clone always renders at 60 fps. when rendering frames.. That one is super annoying.
OS: Windows 10
  •  4
  •  1841
Submitted byclarence_764481
COMMENTS (4)
clarence_764481
the issue is fixed by the latest update thanks
Did you bake the cloth simulation (which should be run in By Frame mode)? After that the cloth behaves like a normal animation and should display correctly for image sequences.
clarence_764481
cheers
Feedback Tracker Admin
Hi, clarence,
The bug that iClone 7 always renders at 60 fps was fixed and released in 7.3.2205.1, the second release of 7.3.
https://www.reallusion.com/FeedBackTracker/Issue/Iclone-7-3-rendering-image-sequences-at-wrong-frame-rate-speed
Please use Reallusion Hub to patch iClone 7 to 7.3.2205.1 if you haven't update yet.
Reallusion
