Votes
0
Product:
Character Creator 5
Version:
5.06
Status:
Released in 5.1
Issue 12510
error with new "Auto Setup for Maya"
before release new version for Maya 2026, "Auto Setup for Maya" working well for Maya 2025 and 2024.
but now I found several error.
1 - "Auto Setup for Maya" has problem with AdvancedSkeleton Maya plugin.
if we have AdvancedSkeleton rig in the Maya scene, "Auto Setup for Maya" not even open.
Video link:
https://drive.google.com/file/d/1k0KZPCvWK84gEt_uVQgX61zemDdkJfzU/view?usp=sharing
2 - if we import FBX and rig face first, AdvancedSkeleton not able to set correct rig. some problem happened for kneed and elbow.
I checked AdvancedSkeleton, working well before "Auto Setup for Maya" make a rig for face.
Video link:
https://drive.google.com/file/d/1UlLRGPMA7eH_q55VBXZCPHI9oRrlZRnj/view?usp=drive_link
I test this issues in Maya 2025 and 2024, both has same issue. I have no idea about Maya 2026
OS: Windows 11
  •  3
  •  595
Submitted bykoulanaj
COMMENTS (3)
Feedback Tracker Admin
Hi koulanaj,
Thank you for your ongoing patience and for working with us on this.
I wanted to give you a quick update on our progress. Our development team is currently prioritizing the AdvancedSkeleton rigging conflict (Issue 2). Since we were able to isolate the cause of the bone and joint distortion, our engineers are actively working on a patch to resolve this rigging order logic.
As for the plugin failing to open (Issue 1), it is proving a bit tricky to replicate consistently in our testing environment right now. However, please rest assured that we are keeping your report open. We will continue to monitor and investigate the UI loading behavior alongside the rigging fix.
We will let you know as soon as the patch for the rigging conflict is ready for you to try.
Best regards,
Kayla
Reallusion
koulanaj
Hi.
thanks for updating.
sure, for issue 1, I just uploaded the file and here is the link.
also here is error message in script editor of Maya
# Error: MayaAttributeError: file C:\Program Files\Autodesk\Maya2024\Python\lib\site-packages\pymel\core\general.py line 2788: Maya Attribute does not exist (or is not unique):: 'char_08:Brows_Hair_Transparency1.subsurfaceWeight'
I have this issue on my PC and my friends laptop. both using win 11
https://drive.google.com/drive/folders/1ZYoVknxm2LRxTQuxEOBN207pJ-U7QYlK?usp=sharing
Hi koulanaj,
Thank you for the detailed bug report and for taking the time to record the videos. We really appreciate you testing this across different versions of Maya.
Regarding Issue 2 (AdvancedSkeleton rigging fails after Auto Setup face rig):
Good news—we have successfully reproduced this issue on our end! We can confirm that applying the Auto Setup facial rig first causes conflicts with AdvancedSkeleton's elbow and knee setups. We have logged this behavior and escalated it to our development team to investigate the rigging order logic.
Regarding Issue 1 (Auto Setup fails to open with AdvancedSkeleton rig in scene):
We have been trying to reproduce this specific conflict in both Maya 2024 and 2025, but the Auto Setup UI currently opens normally for us even with an AdvancedSkeleton rig present in the scene.
Because we cannot trigger this blockage on our end, it might be related to the specific character mesh or a particular setting in your scene. To help our QA team pinpoint exactly where the plugin is failing to load, could you please share both the exact FBX file you are importing and the Maya scene file (.ma or .mb) from your test?
Testing with your exact files will help us replicate your workflow perfectly. You can upload them to Google Drive and share the link with us here.
Thank you for your patience and cooperation!
Best regards,
Kayla
Reallusion
