Votes
0
Product:
iClone 7
Version:
7.83
Status:
Assigned
Issue 7544
iCar Body Shop No Longer Working Properly??
Hello Tech, and Happy New Year! 🎉🎊🎆🎇🎈😁
I want to be able to make my own custom body cars using this particular system (i.e., https://3dwarehouse.sketchup.com/model/61e29a0a6be803f72f2303161abacc54/Car-Turntable-4800mm-Diameter-Paver-Riser-option ), for my upcoming movie creations (Nostalgic, honoring the past of iClone content), but I can't get the wheels to turn using this system. Everything else works fine, even the perform commands. I followed two build instructions, both in which are very detailed instructions, where following either should give the same results of functionality:
* https://www.reallusion.com/ContentStore/iClone/pack/iCar_BodyShop/Help_Assemble.aspx
(your instructions)
* https://www.youtube.com/watch?v=FRHZBSTgsZw
(foreign language, but SUPER easy to follow)
In the example, you will see that my remake (right side) doesn't have the same take off, nor do the wheels even work at all. In the ORIGINAL make (left side), the wheels turn inward for some reason now.
So, it's CLEARLY obvious that there is a problem with this pack/scripting setup. Please fix this, so I can use this in my movie(s).
Thank you in advance for your help!
OS: Windows 10
  •  2
  •  1089
Submitted byLogicalWarrior
COMMENTS (2)
LogicalWarrior
Thank you very much, Molly! It did work!!
Feedback Tracker Admin
Hi LogicalWarrior,
I‘m glad to hear it.If you have any question,please let me know.Thanks.
Molly
Reallusion
Hi LogicalWarrior,
There is a workaround.Please pick R_Front_Wheel & R_Back_Wheel,right-click,choose Remove Object Animation.The wheel will be OK.
Molly
Reallusion
