Votes
0
Product:
3DXchange 7
Version:
7.7
Status:
Not a Bug
Issue 7236
iClone FBX imported to 3dxchange failed to get colors correct.
Hi, i had several props exported as a single fbx from iclone (with animation). The fbx was imported to 3dxchange and exported as a single iProp (with animation). Dragged to iclone scene from the content(custom).
Issues faced was the textures were off for both 3dxchange and iclone.
* i didnt do a direct transfer from iclone to 3dxchange was because i wanted the animation to be included in a single iProp. Direct transfer from iclone to 3dxchange would prompt a remove of all animations in 3dxchange.
OS: Windows 10
  •  1
  •  1934
Submitted byProcrastinator
COMMENTS (1)
Feedback Tracker Admin
Hi Procrastinator,
iClone FBX imported to 3dxchange failed to get colors correct,because FBX file does not include some textures,for example metallic/roughness.If you want to get colors correct,you need laod these textures manually.
When you export FBX from iClone,it will create a texture folder.In the folder,you can find AO/metallic/roughness textures…,then drag metallic/roughness to texture channel.
BR,
Molly
