Votes
0
Product:
Character Creator 5
Version:
5.0
Status:
Closed
Issue 12559
maya 2026.3
MAYA 2026.3 / windows 10
CC fbx file exports and imports via CC auto setup is just fine. only problem, when i run the Face_Rig
it only creates the Face_board within the CC Autosetup window, not floating face_board...
although its visiable on outliner, but only a "+" appears, not the floating board...
In maya 2026 viewport settings everything is selected...
OS: Windows 10
  •  1
  •  138
Submitted byerdinckamisli
COMMENTS (1)
Feedback Tracker Admin
Hi erdinckamisli,
Thank you for contacting us regarding the Face_Rig display issue in Maya.
The behavior of the Face Rig function depends on the specific "Facial Profile" applied to your character. Based on your description, the character you are currently using likely has a Standard or Extended profile.
To see the floating face board directly in the Maya viewport, your character needs to be equipped with a CC5 HD Profile.
You can also refer to our official tutorial video for a quick explanation on this:
    - Video Link: https://youtu.be/2AKEGOgPU7w?t=362 (at the 06:02 mark)
       1. As mentioned in the video, if the character doesn't have a CC5 HD facial profile, the face rig will not appear directly in the viewport, though the controls will still be accessible in the Face Rig tab.
Here is how you can check and find the correct profiles:
    1. Check your current character: You can verify your character's current profile type by opening the Face Key editor in iClone, or the Edit Facial panel in Character Creator.
    2. Find HD characters: In your Content Manager, look for content that has the "HD CC5" tag on the thumbnail. Characters with this tag are equipped with the HD Profile required to generate the floating board in Maya.
Please try exporting a character with a CC5 HD Profile and run the Face_Rig again. Let us know if you need any further assistance!
Best regards,
Kayla
Reallusion
Hi erdincamisli,
I hope you are doing well! I am writing to quickly follow up on your ticket regarding the Face_Rig display issue in Maya.
Were you able to test exporting a character with a CC5 HD Profile as suggested in our previous reply?
Please let us know if the floating face board is now appearing correctly in your viewport, or if you still need any further assistance with this. We are always happy to help!
Thank you for your time.
Best regards,
Kayla
Reallusion
