Votes
Product:
Cartoon Animator 5
Version:
5.32
Status:
Active
Issue 11812
spring animation working while manualy dragging the timeslider ..However when the playback button is pressed, The springdynamics are not showing
1.Added the character( simple image with a spring bone structure) to the stage
2.Animated the root bone manually with the 2d motion key editor
3. When translating the root bone, the spring dynamics works, But when rotating any of the bone, The playback animation showing weird results. The spring dynamics are working if we manually drag the time slider.
4. Tried enabling the "simulate spring feature in playback" option in Preferences as well. No luck
OS: Windows 11
  •  3
  •  735
Submitted byvishnukms61
COMMENTS (3)
flo.zauner
this is not the solution to your problem. I have the same problem and all they say to me is that it is a limitation of the program.
as well as the fact that lots of other features do not work properly. you will just hear that it's a limitation
vishnukms61
Wow! I didn’t expect such a quick response. Thank you, Reallusion team, for addressing my issue so fast and providing a clear solution. I will try that workaround and see how it goes.
Really appreciate the great support!
Feedback Tracker Admin
Hi vishnukms61,
If you are editing the first Bone, you need to set the Spring Bone on the second Bone instead of the first one.
Allen
Reallusion
