Votes
0
Product:
Character Creator 2
Version:
2.01
Status:
Not Reproducible
Issue 2350
will not let me import characters from ccv1 and no option in ic v7 when importing a cc v2 to export in cc v2
i have made a mistake by using cc v1, so i saved the character in a file and also in ic v6 then tried to drag and drop in cc v2 (originally my characters imported fine from cc v1 to cc v2 upon installing) i did manage to get the character in ic v7 but could not export in cc v2.. so i figured no problem and made another similar in cc v2 but when i imported into ic v7 (use only pipelline versions) CC v2 would not highlight or export / import into 3dxchange v7 or cc v2. i can create an fbx or xport to schefab but even the fbx file will not import into 3dxchange v7 (i do not see a work around and think i am missing something but ic v6 works just fine when (in 3d xchange v7 always just a blank screen) i wanted to morph within sculptris, i can probably do this by saving within ic v6 but i would lose the pbr textures i created when moving them into ic v7.. thanx in advance
OS: Windows 7
  •  3
  •  3071
Submitted bySpiderTec
COMMENTS (3)
I loaded a CC2 character into 3DX7, and when I then select "Apply to iClone" in the Modify panel, the character will be loaded into iClone 7.
SpiderTec
NEW UPDATE FOR THIS POST iClone v7 lets me inport export to CC v2, can export into 3dxchange v7 but from 3d xchange to export direct to iclone fails (i save the file then drag and drop into ic v7 as a work around
  thank you for fixing most of the issues by the way
SpiderTec
update:i got it to work from iclone 7 (pre-release version) to 3d xchange,
    but no characters created with CCv2 that i create (even a naked base model without clothes or accessories) that i bring into iclone 7 pre-release will allow me to re-edit in cc v2 (the button is there to edit in cc v2) but it will not highlight after i save the character into the library and bring it into a scene with the character chosen in the scene. and to find the file then drag it into cc v2 or import (from file manager) doesnt work "failed to load file"
note these are characters i just created and testing importing to modify export - import
it seems cc v2 is a 1 way event (can only export) but not import anything unless i load a project in, but i get a 80% chance of getting a "failed to load" error when trying to import previous projects from cc v1 into cc v2
from ic v7 pre-release there is no way to export motions to a character  to cc v2.0 to upload to sketchfab with motions (have not tried 3d xchange yet)
either i am missing a basic step to fix this option or it is too early for this feature to be added before release..  either way i found a work around through 3d xchange (but it doesnt work for all models) in v7
and another issue i found i could not drag and drop (rght or left) click materials onto a custom model i made in obj format into 3d xchange (i had to go into ic v7 then from import from there..  thanx in advance
