Votes
0
Product:
Character Creator 4
Version:
4.02
Status:
Not Reproducible
Issue 8936
After exporting to Maya as FBX, the head/face geometry is messed up internally
After exporting my character as an FBX, with the goal of designing and animating within Maya using the included rig and facial expression blendshapes, there is a weird bug with the head/face part of the geometry. The local, relative positions of all the vertices and faces snap to a location elsewhere on the head. While it looks fine and renders fine, this makes it impossible to rig constraints onto the 'skin' of the character (to track objects on the face geometry) or to use the Make Live/Make Paintable features in Maya (for texture painting and hair/beard designing).
To recreate the problem, import a character into Maya, create a simple object like a poly sphere, and try to constrain it to the face using 'Rivet' or 'Point to Poly' which requires you to select a vertex on the character. The constraint will automatically snap to a random place inside or across the head somewhere.
Note: this error ONLY occurs on the head/face geometry. The constraints and paint features seem to work fine on other parts of the body. For example, if you use Paint FX/Make Paintable and draw a stroke across the chest, it works as expected. But when you draw the brush across the clavicle into the neck area, the brush origin snaps automatically to a random point on the head.
OS: Windows 11
  •  2
  •  1105
Submitted byseencapone
COMMENTS (2)
seencapone
Thanks for following up with me on this. I haven't tried it out with the latest version, but that problem has always been on my mind.
I remember last year I discovered some kind of workaround. I'm doing some new work in CC4 right now, so I'll bring it into Maya and test it out.
Why do you ask after all this time? Has there been an effort on the development side to address this bug?
Thanks,
Sean
Feedback Tracker Admin
Hi seencapone,
Does this issue still occur in latest version?
Thank you for your help!
Calvin
Reallusion
