Votes
0
Product:
Character Creator 4
Version:
4.53
Status:
Fix In Review
Issue 12006
CC periodically decides I don't have licenses for things, and I get a watermark
HI there,
This is the third time this has happened, all with different versions of this one character I'm creating. I've been going back and from Blender via the plugin, and it will be fine for let's say 6 times each way. Then, I'll open the CC4 project file and boom! watermark.
Once it's there, I basically have to go back to an old export and start over, and I have no idea what sets it off.
Here is a link to the file, zipped on my Google Drive. https://drive.google.com/file/d/17i6Nh_6-D-2w1zOK3L--Sha4hfHKpTvj/view?usp=sharing
I am grateful for any help you can give.
Thank you!!! :-)
OS: Windows 11
  •  3
  •  712
Submitted by3DChick
COMMENTS (3)
Feedback Tracker Admin
Hi,3DChick
Thank you for your help!
I apologize for saying the wrong thing earlier. It's expected behavior that it only generates the iClone drmlog.
I'll report this issue to our technical team, thanks again for your help.
Best Reguard
Howard
3DChick
HI Howard!
It happened again, to a completely unrelated file, so I did as you asked, just as you described above. No luck. Here is a Google Drive link, with the problem CC4 problem file, but only a DRMLog file for iClone, because there wasn't one for CC (which strikes me as being a bad thing?).
I included a screenshot of the folder with path, in case I got that wrong somehow. My Windows is set to show all files, if that matters.
https://drive.google.com/file/d/12QU6BM6KdClzhc4JlY_plAVj1WNrBNkf/view?usp=sharing
Thank you for attention to this!! :-)
Hi,3DChick
Thanks for your feedback.
You can go to Menu > Help & Click " Activate Unpurchased Item " check if the watermark is still there.
If the watermark still there please close character creator first, then use the reg file it call "CC4 EnableLogOn" from the link below. After that, reopen character creator and load the file that's causing the watermark.
And then go to this location:%localappdata%/reallusion and find files with the .drmlog extension, file name is " CharacterCreator.2025xxxx_xxxx.DRMLog ", we need that file to find out the cause of the problem.
After that, please close character creator then use the reg file it call "CC4 EnableLogOff".
And then please provide the file to help us identify the problem. Attach the file in your next comment. If the file size is larger than 10MB, you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment.
You can use Private Comment if you want to keep it private.
Best Reguard
Howard
