Votes
Product:
Character Creator 4
Version:
4.61
Status:
Assigned
Issue 12191
CC4 Crashes when converting Accessory to beard or eyebrows
Steps to produce bug:
Import FBX asset using accessory import
Press create hair, brows, beard in the modify panel
Reset facial expressions to default
Options tested: Base/All(Hair) Full Beard (Beard) Brows (Eyebrows)
Hair works fine without issue but beard and eyebrows start to convert then crashes at 10%
Tried two different FBX's one being a beard one being a default box, both cause the crash.
OS: Windows 11
  •  2
  •  450
Submitted byalexjarrett
COMMENTS (2)
alexjarrett
Private Comment
Feedback Tracker Admin
Hi alexjarrett,
I have got it. Thank you for your help.
Molly
Reallusion
Hi alexjarrett,
I can't repeat it.Can you provide your character file to help us identify the problem?Please attach the file in your next comment. If the file size is larger than 10MB, you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment. You can use Private Comment if you want to keep it private.
Your help is highly appreciated.
Molly
Reallusion
