Votes
0
Product:
Character Creator 4
Version:
4.52
Status:
Not a Bug
Issue 11696
Character's symmetry is broken and Mirror Copy does nothing.
I have a character, and for whatever reason her middle line is broken, and she has asymmetrical features. There is no way to fix it, I've tried using Edit Mesh, and clicking on Mirror Copy with all vertices selected, some vertices selected, none vertices selected, it always produces the same result - nothing changes. I don't even see an attempt to move a single vert from the software. Tried different mirror tolerance setting, too. It's super annoying, as in Unreal I need the character to be symmetrical, so I can also produce clothing easily.
OS: Windows 10
  •  1
  •  524
Submitted bylena_768280
COMMENTS (1)
Feedback Tracker Admin
Hello lena_768280,
For this case, the current solution is to export the character as an FBX file to an external program, use the mesh mirroring functionality to adjust the topology and mesh, and then re-import the character as an FBX file back into CC.
Please note:
When editing externally, do not change the character's vertex count.
Ensure you use the same character's FBX key when re-importing into CC.
Thank you.
Tina
