Crashes with many Character parts on Humanoid/Non Native Characters with the FPE -workaround creates a BIG problem
Please provide the option to make Character parts that are weight painted, "Sub-items" on Humanoid/Non Native Characters or allow us to separate merged items keeping it's weight painting and quad structure in tact. In my previous post we (Myself and Rampa) discovered a problem with character complexity(many character items) and trying to create Facial morphs with the FPE (Facial Expression Editor) GoZ process: -----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------https://www.reallusion.com/FeedBackTracker/Issue/Urgent-Help-needed-Facial-Profile-Editor-Crashes-On-two-Powerful-Machines-with-latest-Face-Tools-update -----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
The workaround was to merge all non body parts in order to be able to use GoZ.. however, this introduces a BIG problem which is that the character items can no no longer be isolated for exclusive/controlled weight painting!!
In order to mitigate complex character creation process, parts should be able to be merged as Sub-items or allow us to separate the parts as skin weighted character parts/items *without* creating Tris as it's known in the mesh editor when separating.
The problem of dealing with complex characters sending over to Zbrush from within Facial Profile Editor might be an issue of CPUs For Example Rampa had reported to me that he was using an 12th generation i5 and I'm using an AMD 16 core/32 Thread @5GHz and 128 GB of ram - he was able to merge all non body parts all at once, I was only able to merge a few at a time or else CC4 would crash, maybe it's a memory leak/allocation issue dealing with AMD CPUs in CC4.
HI Ascensi
Could you try updating your software version to the latest one? It might help resolve your issue.
It still doesn't work. You may need to provide your file and the version of ZBrush you're using, and record an operation video to upload it to YouTube or Google Drive.
Kayla
Reallusion
Feedback Tracker Admin
Hi Ascensi
Don't know if you have solved the problem yet.
If not, I hope you can help us by recording an operation video and uploading it to YouTube or Google Drive.
Kayla
Realluison
You are going to edit a submitted issue. This issue will be changed to private draft mode until you click submit again. Are you sure?
