Votes
Product:
Character Creator 4
Version:
4.52
Status:
Active
Issue 11685
Delete a custom morph and remove this where it was used on other custom characters.
In Character Creator 4 when you delete a custom morph. Is it then possible to reset the morph where it was used on other custom characters automatically?
Se attached images ;)
OS: Windows 11
  •  1
  •  451
Submitted byJacobHansenLaerdal
COMMENTS (1)
JacobHansenLaerdal
From Reallusion:
Thank you for contacting Reallusion.
You will need the slider to reset the morph. It will not automatically remove from all the characters it was applied to. The mesh has already been changed.
When you delete a custom morph it puts it in your Windows recycle bin, so check if you have it in there. You can then apply it at -100 to remove the mesh deformation. The slider will not go negative, but if you type directly into the number value box it can over/under driven.
Me (solution):
Yes, as you say, I was afraid that this was the case. But of course, we can create a Python script that finds the custom morph in our custom characters and then resets the morph before we delete the morph from the Neutral Base CC3+ character.
