Votes
0
Product:
Character Creator 4
Version:
4.62
Status:
Released in 5.05
Issue 12287
Error import DAZ genesis 9
Untill a few months ago i was able to import characters from Daz Genesis 9, using 2014 or 2016 bin export. But now doesn't work. Cc4 import only morph but texture, it say : NO COMPATIBLE PROFILE (reverse). So the characters are completelly different. I think is a INI missing files, problem. Please check.
I also tried to install a precedent version of CC4, but same problem. I really need to be able to import daz genesis 9 characters for my work. I'm stuck by a month with this problem. please fix it.
OS: Windows 10
  •  2
  •  481
Submitted bylord.atilak
COMMENTS (2)
Feedback Tracker Admin
Hi,
I also tested with DAZ Genesis 9, and it works normally, as shown in the attached image. Please provide your DAZ file so we can test it. Thank you.
Soya
Reallusion
Mafutre
Hello Atilak,
I'm using the last version of CC4, and it still works with G9 characters.
I export from DAZ as a FBX 2014 bin, import on CC4 in Advanced mode, then :
- check "Bake body texture"
- select 4096 size
- click "Generate Profile" and create a new file
- select texture folder in the proper  DAZ character's path
I hope it will help you
