Votes
0
Product:
iClone 8
Version:
8.63
Status:
Not Reproducible
Issue 12392
Export and Skin issue
Hello,
A character created in Character Creator and animated in iClone is transferred to Blender for rendering (exporting via plugin or as an FBX file has the same effect).
I'm using the latest versions of iClone 8, Character Creator 5, and Blender 5.01 with the latest plugin for Blender iClone and Character Creator (2.3.3; the previous plugin had the same problems).
In some scenes, I have vertical lines in the skin texture, which are particularly noticeable when using compositing. So far, I haven't found any setting or transfer method that prevents this. In the example image, this problem only appeared at frame 67. Neither adjusting the lighting nor changing the compositing makes a difference.
Does anyone know a solution?
Thank you.
Thorsten
OS: Windows 11
  •  2
  •  491
Submitted byThorstenMihm
COMMENTS (2)
Feedback Tracker Admin
Hi ThorstenMihm,
We sincerely apologize for the inconvenience this has caused you.
Since we are currently unable to reproduce the issue on our end, would it be possible for you to provide your project file? This would greatly help our team to investigate the cause further.
Thank you for your patience and cooperation.
Best regards,
jasmine
Reallusion
Hi ThorstenMihm,
Thank you for your feedback. We sincerely apologize for the inconvenience this has caused you.
Regarding the skin texture issue, we recommend that you first update to the latest version and check if the problem persists.
If the issue remains, could you please provide your project file to help our team investigate further?
If the file size is too large, you may upload it to a cloud service (e.g., Google Drive) and share the link.
To protect your privacy, you can check the "Private Comment" option when replying so that only our staff can see your message and files.
We look forward to your reply. Thank you for your patience and cooperation.
Have a nice day
jasmine
Reallusion
