Votes
0
Product:
iClone 7
Version:
7.41
Status:
Released in 7.41
Issue 5662
Filename format of rendered images is incompatible with many video editing suites
This is a re-opening of Issue #5446... It is marked as "Released" but is not solved.
TITLE: Image sequence filenames are incorrect when starting Iray batch renderer manually
LINK: https://www.reallusion.com/FeedBackTracker/Issue/Image-sequence-filenames-are-incorrect-when-starting-Iray-batch-renderer-manually/1/naming
EXPECTED BEHAVIOR:
The "frame number" should be the last part of the filename.
EXAMPLE:
If the files for the frame are named "test_00001.mi", etc., the corresponding image file should be named "test_RGB_00001".
OS: Windows 7
  •  2
  •  1655
Submitted byjustaviking
COMMENTS (2)
Feedback Tracker Admin
Released in Iray Render Plug-in v1.11
The sequence number is now moved to the last part of the filename.
This issue must be addressed before a final release, otherwise exported image sequences are useless for many users.
