Votes
0
Product:
iClone 7
Version:
7.41
Status:
Released in 7.41
Issue 5679
Image Sequence Bug with Premiere and Naming Convention.
Hello,
When rendering an image sequence format through Iray, the naming convention is quite wacky and it will not be able to import into Adobe Premiere CC. It will name something like 'Random Girl_00003_RGB' 'Random Girl_00004_RGB'
When I rename the file to Random Girl_RGB_00004, it will import correctly, but I would have to rename every single image in order for it to work.
OS: Windows 10
  •  2
  •  2376
Submitted by4413Media
COMMENTS (2)
Feedback Tracker Admin
Released in Iray Render Plug-in v1.11
The sequence number is now moved to the last part of the filename.
Can(RL)
Hi BenjaminTuttle,
The way Iray image name is saved(Name_#####_AOV type.format), it makes it hard for post production software to import sequences.
Team will fix in next patch.
For quick workaround, please download the python file below :
https://goo.gl/2s52c3
Example :
https://youtu.be/txDldcydvB0
Thanks,
Can(RL)
