Votes
0
Product:
Character Creator 4
Version:
4.42
Status:
Released in 4.5
Issue 11379
GOZ from CC4 to zbrush not working
I am not able to export rigged characters from cc4 to Zbrush using GOZ. (zbrush 2022.7)
a window pops up with a message i have to close zbrush.
after doing that CC is not able to relink to my hi res model.
I keep getting same problems with different models exporting from zbrush with GOZ plus.
before updating cc to the latest version, i was getting another error : "Interface does not have special modifiers"
What is wrong here?
Thanks for your help
OS: Windows 11
  •  13
  •  5077
Submitted bythomasbregulla66
1 23
COMMENTS (13)
thomasbregulla66
thanks very much for your help!
i deleted the 2023 zbrush registry as shown in the video and added the attached file to cc4.
I can now use GOZ between cc4 and zbrush with no problems.
Awesome
thomasbregulla66
Hey, I guess you forgot to attach the zip to your last answer...I cant find a zip ;D
Feedback Tracker Admin
If you don't want to refer to the video for deleting the zb registry, you can use the CC version that was just build.
Download the dll file and copy it to this path:
C:\Program Files\Reallusion\Character Creator 4\Bin64\Plugin
Please let us know if this version works. Thank you.
ChengJhong(RL)
Currently, the install problem may be cause by the reigstry provided by ZBrush, the ZBrush 2023.0.1, if you don't have that version installed, please delete it manually. I attached a zip with .mp4 to demonstrate how to delete it. If you want to keep that registry, you can just rename it to ZB 2023.0.1, then test with goz plus sending from Character Creator.
thomasbregulla66
Private Comment
thomasbregulla66
Private Comment
1 23
