Votes
0
Product:
Character Creator 4
Version:
4.62
Status:
Released in 4.63
Issue 12239
GoZ from CC4 to Zbrush scaling issue with imploding mesh. Match Zbrush Model scale option is faulty!
Hi I am here after resending a ticket as I feel my first ticket was not resolved properly, so need a second opinion & better support. The support admin is only telling me to see updates on the hub with no real solution.
PROBLEM:
I tried to GoZ my character from CC4 with my character - when it opened in zbrush I found out the current imploded mesh issue
Steps:
1/ I opened a CC4 default character & tried to GoZ it. I selected "Match Zbrush Model scale" check box then confirmed.
2/Zbrush opened deformed/imploded mesh
3/ I trouble shot by opening zbrush "Preference/ Goz/Clear cache files" - then tried to repeat the process but got the same result
3/ I tried my custom character, but this time did not select "Match Zbrush Model scale" & it worked - however that only worked that one time.
4/ Now every time I try a default character or my own characters it happens all the time creating an imploded mesh.
5/ When I export back from zbrush to CC4 & select scale to CC4 check box the mesh appears as a black silhouette only.
This never happened before until the recent updates during CC5 release. I am somewhat reluctant to purchase & upgrade to CC5 from CC4. However I had used the CC5 trial & tried GoZ with my character & the same thing happened as well.
Attached are recent tests (CC4 only) showing the issue still is happening.
The reallusion support said I must of scaled something for it to do that issue but I have done no such thing - case in point I used a default character from CC4 doing a straight export as in step 1/.
They even tried to give me a work around, but it doesn't really work & causes so much more problems making the process take so long when the "Match Zbrush Model scale" used to work just fine.
Thanks for you time & please resolve whatever is happening with the "Match Zbrush Model scale" as I have tried to find documentation for this issue, which seems to be happening a lot I see.
Have a good day
OS: Windows 11
  •  1
  •  880
Submitted bypopislander
COMMENTS (1)
Feedback Tracker Admin
Hi,
This issue is related to the Normal setting. We are already working on it. In the meantime, you can temporarily set Normal to None, and it will work properly.
Soya
Reallusion
