Votes
0
Product:
Character Creator 4
Version:
4.42
Status:
Active
Issue 11399
Goz plus plugin problem?
When I upgraded to the latest version 4.42 of Character Creator, I got the new "Goz plus" plugin and when I try to send a character to Zbrush, nothing happends, not even an error message. I have used this workflow a lot, so I think my setup is correct.
I have read somewhere that the new version only supports Zbrush 2022.0.8 and up (I have 2022.0.7), is this true?
If I can't use the new version, can I downgrade to the old plugin?
OS: Windows 11
  •  3
  •  1257
Submitted byTanobi
COMMENTS (3)
Feedback Tracker Admin
Hello,
The minimum version supported by GoZ Plus is 2022.0.8. If you wish to have support for a lower version, please follow the steps below:
step1: Launch the minimum version of ZBrush (ex: 2022.0.7)
step2: In LightBox, apply "Cube.ZPR"
step3: Go to Tool > Save As > Reference.ztl
step4: Replace the file (Reference.ztl) at this path: C:\Program Files\Pixologic\ZBrush 2022\ZStartup\ZPlugs64\CCGoZData
Tips: For Maxon One version, please also use the corresponding path.
Soya
Reallusion
Tanobi
I have already tried that, but it did not work.
Tanobi
I’m currently on holliday and can not perform the check you are suggesting but as I wrote in my initial comment, I’m usung ZBrush version 2022.0.7 and have not changed that since installing it in 2022. I have never owned a Maxxon version of ZBrush, only the last perpetual licence from Pixologic (version 2022.0.7). Thats why I asked if the new Goz plus plugin supports this version?
I'm not sure if your zb was renamed or the ap location changed.
We need your ZB version information. To collect the ZB version from your computer, please follow these steps:
1. Download the .bat file (SaveReg_DriveC.bat) from here.
https://drive.google.com/drive/folders/1xubbKGinNY3BeIh3qEgVlm6JGVSMVq17?usp=sharing
2. Double-click it.
3. Send us two registry files from your C Drive. Please see the attached picture.
Soya
Reallusion
Hi,
Please reference this issue. If GoZ Plus still doesn't work, please let us know. Thank you.
https://www.reallusion.com/FeedBackTracker/Issue/GOZ-from-CC4-to-zbrush-not-working
Soya
Reallusion
