Votes
Product:
Character Creator 4
Version:
4.7
Status:
Active
Issue 12606
I cannot use GoZ
Error is instant on clicking GoZ (not a timeout)
ZBrush→CC4 works fine, only CC4→ZBrush fails
Started after an interrupted transfer
All config files, registry entries, and plugin files check out correctly
Resource config had a stale 2018 dev path (D:\IC\CC3.0dev...)
CC4 writes no logs
OS: Windows 11
  •  3
  •  192
Submitted bymastajappa
COMMENTS (3)
mastajappa
Indeed onedrive was the reason. Satya Nadella needs to face conscequences. Thanks for the support!
mastajappa
I am not willingly using OneDrive but it might be the culprit in this situation. Shall I nuke it?
Feedback Tracker Admin
Hi,
Are you using OneDrive? If so, please set the Documents folder to not be backed up, because OneDrive has its own backup mechanism, which may interfere with ZB’s ability to write data.
Soya
Reallusion
