Votes
3
Product:
Character Creator 4
Version:
4.4
Status:
Not Reproducible
Issue 11047
Morph Editor doesn't work for me
Steps to reproduce this bug:
1- Download the project folder
2- Carefully watch this tutorial -> https://youtu.be/o2pda-px7N4?si=F3rCIVXvVrUQ_OWu (in between 0:00 and 3:00)
3- Create a CC4 project with a "Neutral_F" base actor in it
4- Reset all Morphs
5- Go to "Create" > Morph Slider Editor
6- Create a Morph Name.
Set Source Morph to "Default Morph".
Set Target Morph to "File" and select the .obj inside the project.
Check "Adjust Bones to Fit Morph" and "Auto apply to current character"
7- Click "OK"
The result: Nothing. The morph will not be applied, and no morph slider will be created.
Desired result: Like in the tutorial, the morph is applied to the default character.
Context: I am a new user to CC4, I purshased the software last Friday (Friday 15 December 2023). I have experienced several crash for obscure reasons (Ex: dragging an base actor into the 3D workspace makes CC4 crashes / Trying to import a i.Avatar while CC4 is open on a fairly recent project makes the software crashes)
I'm using Blender 3.6.2, I've installed the CC/iC Pipeline Add on to import and export CC4 base characters.
OS: Windows 10
  •  4
  •  2534
Submitted byArt Team Ohrizon
COMMENTS (4)
stephan.anemaat
Hi team, I also have the exact same issue. Here is a video capture showing the issue that OP is reporting:
https://www.youtube.com/watch?v=2W0OKxwnvYQ
Feedback Tracker Admin
Hi stephan.anemaat ,
Please capture a picture about Content Manager Settings panel and find the Custom folder,then check if you have Avatar Control folder in Reallusion Custom.
\Reallusion Custom\Actor\Avatar Control
If you have Avatar Control folder,please provide your target morph character to us.Please attach the file in your next comment. If the file size is larger than 10MB, you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment. You can use Private Comment if you want to keep it private.
Molly
Reallusion
Hi Art Team Ohrizon,
Can you capture a screen video?
Molly
Reallusion
It works for me.Can you capture a screen video about this issue, put it on the YouTube, and add the link in your next comment.
Your help is highly appreciated.
Molly
Reallusion
mirzaym
I have the same problem, Developers have not yet been helpful on solving the problem. I bought the software and still cannot use it.
