Votes
0
Product:
Character Creator 4
Version:
4.12
Status:
Assigned
Issue 9104
Pose Offset issue with Mirror check box
There is an issue with Pose Offset while using mirror check box for symmetry.
If you leave this box checked, every second bone you select would produce an unpredictable result for the mirrored bone.
You have to keep unchecking and checking back the mirror check box for every other bone you work with:
https://vimeo.com/777639815
OS: Windows 10
  •  1
  •  638
Submitted by4u2ges
COMMENTS (1)
Feedback Tracker Admin
Hi 4u2ges
Thanks for your feedback!
This issue has been reported to our dev team and will be fixed in future version.
The current solution is to uncheck the Mirror check box and check it again after adjusting the bone, and then adjust the next bone.
Thank you.
Tina
